Help wiring Nest Learning Thermostat for my Dual Fuel System
Jaredwheet
I have a dual fuel system. It has a heat pump that runs until the outside temp is 25 degrees. When that happens the furnace will kick on instead. I am attaching a pic of my current thermostat wiring. Can someone help tell me where these wires should go on a Nest 3rd Gen Learning Thermostat?
Thanks!
6 REPLIES 6
Jaredwheet
The furnace is Gas, the heat pump is electric.
EdwardT
Hi Jaredwheet,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. How is your Nest Thermostat currently wired? To isolate the issue, please try the following wiring:
W1 - White
R - Red
OB - Orange
Y - Yellow
G - Green
C - Blue
Let us know how it goes.
Edward
When doing the Pro setup can you help with each wire and how it should be setup?
EdwardT
Hi Jaredwheet,
Thanks for the response. Did you get an option to set it up as a homeowner? Please share a photo of what you're seeing on your thermostat so we can take a closer look.
Edward
EdwardT
Hi Jaredwheet,
Edward
EdwardT
Hi Jaredwheet,
Edward
