03-21-2023 10:37 AM
4 days ago my nest thermostat e just disconnected from the WiFi and I can't work out how to reconnect. I follow the troubleshoot and it doesn't troubleshoot my error at all, my WiFi works fine, I've moved it closer to my WiFi hub, to the hive, the thermostat just has a picture of a phone with the house nest logo.. It's worked fine for over a year... I'm lost on how to fix it. Troubleshooter says click on settings on thermostat... Mine won't let me do any menus on the thermostat
03-21-2023 01:09 PM
Hello @MattRo,
Thanks for reaching out. Did you try factory resetting the thermostat? Here's a guide on how to get that done. You can then try to reconnect it to your Home app.
Hope that helps! 🙂
03-22-2023 08:46 AM
The Nest Thermostat E gets installed in the Google Nest app and NOT in the Google Home app. Once installed, it should then appear in the Google Home app.
03-22-2023 03:54 PM
I'm using the Google nest app, I don't have a Google home app.
03-22-2023 03:53 PM
Thanks, but as I mentioned I cannot access any settings on the thermostat
03-24-2023 02:10 AM
How do you factory reset the thermostat? It won't allow to access any options on the thermostat
03-24-2023 06:33 AM
We don't have a Nest thermostat. However, the Google Nest Help topic on restarting and resetting thermostats has a section at the end entitled "Manually restart if your Nest thermostat is frozen", saying "We only recommend this method if your thermostat is stuck or frozen, and you can’t reach the menu to restart your thermostat as described in the section above."
04-07-2023 12:24 PM
@MattRo, thanks for posting here in Community. How's it going with your Nest Thermostat? Were you able to read the information that @MplsCustomer has shared? In case you have an update, let us know and we'll be happy to help.
I appreciate the help, @listairee.
04-11-2023 01:41 PM - edited 04-11-2023 01:42 PM
I appreciate your help, @listairee, @MplsCustomer, and Zoe.
04-12-2023 01:51 PM
