07-15-2023 07:07 PM
Is my system compatible with the nest thermostat?
07-19-2023 09:57 AM
Hi jmizzy,
Thanks for posting in the Google Nest Community forum. It looks like you have a proprietary system which isn't compatible with Nest Thermostats. However, some proprietary systems can be rewired by a pro installer to be compatible.
You can visit this support article to know more about the compatibility of a system to the Nest Thermostats.
07-22-2023 10:59 AM
I want to check if there might be anything else you needed on this or if you had any other questions. If there's more you need, just let us know.
07-23-2023 02:06 PM
Hey jmizzy,
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
Thanks for your help, Zoe.
