Hold temperature control?
Alannc
Does “hold temperature “ prevent someone from manually changing temperature?
Alannc
Thanks. NEST should make this clear and also clearly show which thermostats do not have the lock feature
2 REPLIES 2
JillG
Hi @Alannc
No, somebody could manually change the temp by going into the settings.  Hold temperature feature is mostly aimed at overriding any other temp settings you already have.
Hold the temperature on the Nest Thermostat - Google Nest Help
Alannc
