10-27-2021 12:31 PM
Basically, the nest control is not charging. It is not connected to the wall, but charges wirh a usb cable.
now it keeps switching itself off.
I need help, what should I do
10-28-2021 08:48 AM
If your nest thermostat runs on 4 wires configuration , the charging will be only on steal mode, or said trickle charging , at up to 40 mA, which could be easily end up to low battery and shut off the nest thermostat . There many things could cause nest thermostat to consume more powers , like unable to connect to WIFI and cause continues re-try .
Add or connect C wire will improve charging greatly , make charging current up to 200mA , and this would enough to most of the cases . If in a situation still have charging problem , one solution is to install an extra 24v power adapter to supply 24v power on wire C and Rc .
10-30-2021 01:52 PM
thank you for replying. But this doesn’t help me as the unit was never connected to the wall. It was only plugged into a socket. Unless you are now saying that I have to connect it to the wall for it to work.
11-14-2021 11:56 PM
Some instruction on how to connect the extra cables to be able to supply a load at 200mA please
11-14-2021 11:50 PM
Hello, my thermostat only lasts a few hours with load, in order to use it I am giving it a load daily, how can I solve that please?
12-28-2021 01:54 PM
Did anyone get an answer here? Lol
02-12-2022 07:32 AM
My charging cable will not connect
02-12-2022 07:34 AM
The charging cable will not go in slot
