I need help for connect wire
Davidle
Hi, i bought a Nest Learning  thermostat. I already have a Honeywell thermostat with the wiring in the photo.
12 REPLIES 12
EdwardT
Hi Davidle,
Thanks for reaching out. I'd love to know more about this. Could you share the model of your current thermostat? Also, what type of HVAC system do you have?
Edward
Hello there,
Thanks for assisting, Edward.
@Davidle, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Mainak
Hello Team,
I need some help on connecting the wires from my existing Emerson thermostat to the Nest Learning Thermostat.
Hello there,
@Davidle, It appears to be compatible with the Nest Learning Thermostat. Make sure to follow the wiring diagram on your thermostat. In addition, the wire labeled "L" could be an indicator light. Nest Thermostats do not need this wire, as they use their LCD display instead of an indicator light.
@Mainak, Thanks for posting on this thread. to know your system's compatibility with the Nest Learning Thermostat. Could you also send us a picture of your thermostat's wiring diagram? I'll look forward to your response.
Hello Mark,
Thank you for getting back, Below is the wiring picture of the existing Emerson thermostat
Hi Mainak,
Thanks for posting your thermostat wiring diagram. Big help!
Nest Thermostats don’t use jumper wires, but if your current thermostat has a jumper wire, your system may still be Nest compatible. Make sure to follow the wiring setup when you install it with the Nest Thermostat.
Please let us know if you have more questions.
Ebedia
Hello there,
It's us again. How's it going with your Nest Thermostat? Were you able to wire it properly? Don't hesitate to give us your update here. Let us know if you have more questions in mind.
Thanks for lending a hand, Edward and Mark.
Hello folks,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we close this thread in 24 hours.
Mainak
Hello Everyone, thanks for checking with me. I could not proceed with installing the thermostat because I’m not able to figure out which wires go where the last time I was trying to work on the circuit diagram.
I will try again and post the results. It will be great if someone can validate
Hello Mainak,
Thanks for getting back to us. I understand that wiring can be confusing, but here's how you should label your system's wires to the Nest Thermostat:
  • Y (yellow)
  • G (green)
  • W (white)
  • R (red)
Please let me know if you have more questions.
I'm checking back in — how's it going? Still need our help? Let us know so we can assist you right away.
Juni
Hello there,
We haven’t heard back from you, so I'll be locking this thread in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Juni
