10-30-2024 01:33 AM
I’ve been having a really odd issue with our nest for about 3 weeks. It only impacts the hot water, our heating works fine. Boiler is a recently serviced system which heats a tank.
When I ask for hot water either via the schedule or a manual boost the nest app and device say it’s boosting but nothing happens on the boiler. If I do the same and ask for heating it works fine. If I press manual on the heat link the heating comes on but again no hot water is sent to heat.
The odd thing is if I reset the nest it works for 2/3 days and then stops again. Makes it hard to know when to call out an engineer as it’s such an intermittent fault.
Fitted in 2021 so out of warranty. Does this mean Google won’t help?
10-30-2024 03:26 AM
I assume you are in the UK?
Have you tested the contacts for the water terminal 4- 5 -6?
Who supplied the thermostat? ie shop or installer etc.?
10-30-2024 04:23 AM
UK based.
Is testing the water contacts something I can do myself?
Bought online and installed with the new boiler in 2021, has worked perfectly since.
10-30-2024 04:54 AM
I have no idea if your capabilities, but if you have a neon screwdriver, then I would assume so!!
You say it works sometimes, which makes me think it’s a boiler issue. Have you had you motorised valves checked?
11-02-2024 05:46 PM
Hi, @Jo83,
Thank you so much for reaching out to the community. I’m truly sorry you are having trouble controlling hot water. I’m happy to help you and find a solution!
To effectively troubleshoot, please provide the following information:
This information will help me to provide you with accurate troubleshooting steps. Thanks in advance.
Keep me posted.
Ana
