02-09-2022 05:44 PM
This is my current thermostat that I am trying to replace with a Google Nest. Will this work with the Nest?
02-11-2022 08:00 PM
Your best bet is to use the Google Nest compatibility checker.
https://support.google.com/googlenest/answer/9246656?hl=en#zippy=%2Cuse-the-compatibility-checker
02-16-2022 02:00 PM
hey everyone,
Thanks for being here.
@johnCNA, thank you for helping out.
@Atomax, were you able to check it out from the online compatibility checker? If you still need help, please take a clearer photo and indicate the labels of your wire for us to better check your system compatibility.
I hope to hear from you soon.
Ryan
02-20-2022 09:01 AM
Hey Atomax,
I just wanted to follow up and see if you still need help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
02-23-2022 09:57 AM
Have a great day.
Ryan
02-23-2022 11:30 AM
Sorry, I’ve been trying to figure out how to post photos of my current setup. I found this community through the compatibility checker. Basically, I have wires connected to the following:
02-23-2022 01:06 PM
Hey Atomax,
Thanks for the update.
Based on your wiring labels, it looks to be compatible with Nest Thermostat (as long as it is a 24V HVAC system)
Also, one of the good things is that your system already has a C wire. You'll then need to connect these wires to Nest Thermostat to the same label on Nest Thermostat terminal.
Let me know how it goes by replying to this thread.
Ryan
06-07-2022 04:45 PM
Hope this helps!
Kind regards,
Ryan
