10-21-2021 06:30 PM
I'm setting up a new Nest Thermostat. I'm replacing a Honeywell connected thermostat. I have 5 wires.
Blue to C, Green to G, Yellow to Y, White to O/B and Red to R
I went through the set up process and attached the wires per the recommend locations, which corresponded to what I had. Blue to C, Green to G, Yellow to Y, White to O/B and Red to R
I have pictures attached.
The issue is, when I turned the AC on, both the AC and the Furnace both turn on. I disconnected the wires and reconnected, but same issue. I took the Nest off and put on my old unit and it's working fine.
Thoughts?
10-21-2021 06:38 PM - edited 10-21-2021 07:28 PM
This is my setup and compare
but if I’m not mistaken the white wire has to go in to the W terminal
https://www.flickr.com/photos/80134125@N04/shares/554g14
also check out this guy’s tutorial about wiring your thermostat
10-22-2021 06:51 AM - edited 10-22-2021 07:03 AM
So, I hooked up the white wire to the white terminal on the Nest (shouldn't have been on the the OB) and the AC turns on without the furnace.
The issue I have now, is the heat is turning on the fan, but not the furnace.
10-22-2021 05:23 PM
Issue resolved. I needed to reset the unit to recognize the new wires.
11-09-2021 10:41 AM
It looks like we have come to a solution so I'm going to be locking this thread. If you have any other concerns or questions, please feel free to create a new thread.
Have a great day.
Garrett DS
