02-14-2023 04:19 AM
I have a part of our building that loses temperature quickly and takes forever to recover so I would like to narrow the gap between the temperature it is set at and the low temperature it allows. I don't have on ECO mode, I can't adjust the saftey temperature higher than 45 degrees. I can't seem to adjust the low temperature. It doesn't seem to be impacted by any sort of scheduling changes. I am trying to hold 73 degrees, or at least no lower than 70 in that room, but every morning when I come in at 7 it is in the low 60's and takes more than 5 hours to hit 73. Any help would be greatly appreciated.
02-14-2023 04:25 AM
I think perhaps the "home/away" assist might have been the problem. When I leave at night it powers it down to save energy.... Is that a possible solution?
03-09-2023 09:44 AM
Hi Dabrmi,
Thanks for reaching out. When you set your Nest Thermostat to hold the temperature, it is supposed to ignore scheduled or automatic temperature changes for a while and stay at a specific temperature even you're at Home or Away. I suggest reinstalling your Google Home app then try to set a Hold temperature again.
Note: If you're using the Eco preset, you can also choose None to hold the temperature indefinitely until you end the hold. For other presets, your thermostat can hold the temperature for up to 24 hours.
For more information, check out this support article.
03-12-2023 11:32 AM
Hello Dabrmi,
I wanted to follow up if you still need help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
03-13-2023 11:38 AM
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
03-14-2023 04:29 AM
I finally figured out that when I left work the thermostats would go into a power saving mode. Once I figured that out and turned the feature off, everything started working great. Thanks for reaching out.
03-15-2023 12:18 PM
I am glad to hear you were able to resolve the issue, and everything is good to go from here. With that being the case, I am going to go ahead and lock the thread at this time. If you have any questions from here, please feel free to create a new post.
