11-24-2022 05:39 AM
I have a Nest thermostat and l have had to replace the batteries twice because of low battery. I was wondering if the batteries are low or I can’t replace them in time, does the thermostat still function and keep the furnace working for heat or cool?
Thanks
11-24-2022 10:28 AM
Do you have Nest Power Connector or c wire?
11-27-2022 02:43 AM
I spoke with Google support and after going through a number of things, they said the unit might be faulty. Exchanges it for a Nest Learning thermostat. No problems and no worries. Thanks anyway.
11-29-2022 11:45 AM
Thank you so much eveluna for the help.
I wanted to follow up with you. I am glad you were able to get in contact with support, and they were able to replace the device. Please let me know if you have any questions from here, as I would be happy to take a closer look.
12-02-2022 10:38 AM
12-04-2022 02:36 PM
Hello LewisB,
Chiming in to check if you have additional questions or concerns, as we will be locking this thread within 24 hours.
