10-16-2022 03:16 PM
I'm trying to install the learning thermostat and it keep saying there is no power to my R wires. I've tried plugging my red wire into my Rh and Rc connection but the nest will just say there's no power detected to whichever one I have it plugged in. My system is turned back on and I've made sure the wires are pushed in all the way. Using Gas forced air furnace
10-21-2022 01:43 PM
Hello lmn5588,
Thank you for taking the time in letting us know about your inquiry. I'd be happy to take a look into this for you.
To isolate:
Have a look at this article and let us know if you need more help.
10-24-2022 05:25 PM
Hey lmn5588,
Edward
10-25-2022 05:50 PM
Hi lmn5588,
Edward
10-26-2022 11:44 AM
Hi Edward, sorry for the late reply. I responded in my email and didn't realize it didn't send through. We've had our HVAC company come out to diagnose the issue of why the nest thermostat isn't connecting and they keep telling us we need to pay for a rewiring to add additional wires. They keep telling us we don't have the common wire for the nest to communicate with the furnace. Can you validate this?
10-26-2022 12:03 PM
Not sure if this helps but these are the wires we currently have in the thermostat we're trying to replace. The nest thermostat keeps giving us errors with the red wire no matter where we plug it in (tried both RC and RH)
10-26-2022 03:08 PM
Hi lmn5588,
Thanks for the update. If your HVAC tech isolated that your Nest may need a C wire, it's possible that your Nest Thermostat is not getting consistent power and you may really need to install a C wire or a Nest Power Connector. Also, if you haven't yet, you could check this link for other troubleshooting steps you could try.
Edward
10-31-2022 11:03 AM
11-01-2022 11:09 AM
Mel
10-26-2022 11:47 AM
Hello Mark,
We got the error upon trying to boot up the nest after installing all the wires. We do not have a C wire, but all the other wires are seated firmly. Our air filters are new and was placed in with the furnace we just purchased recently
