Need help replacing
Jessamaro67
Does not charge anymore
@Jessamaro67 if your nest thermostat is less than 12 months old, you can get a warranty replacement for it. If you use a nest pro to install your system, your warranty is extended to 36 months. On the other hand, your warranty has expired. You simply have to purchase a replacement unit.
AC Cooling Wizard
