04-23-2024 01:23 PM
04-26-2024 10:37 AM
Hi there Britton3288,
Thanks for reaching out to our community!
If your thermostat wires have the labels RH, RC, Y1, G, and W1, any Nest thermostat will work with your system.
There seems to be a jumper wire between RH and RC. This jumper wire is not necessary, and you can insert the red wire in the RH terminal for a Nest Learning Thermostat and the R terminal for a Nest Thermostat, however, a Nest thermostat might require the installation of a C wire.
You can visit the Google store to see which thermostat might suit your needs.
Angel.
