Need help verifying Nest thermostat compatibility with existing Trane.
3of_aKind
Hello!
    Just picked up the less expensive model Nest thermostat and from what I am seeing off of other forums is that I may need the newer learning model Is it going to be possible to use the thermostat that I just picked up? Also, If you have advice or suggestions as to how I should run the wires.
Not sure how to upload image through here but I have a picture uploaded on their old support site.
Need to verify Nest thermostat compatibility with existing Trane thermostat. - Google Nest Community
Thank you in advance!
-Kyle
Hey Kyle,
I would be more than happy to assist you and ensure you are fully compatible with the right thermostat. I would recommend using our compatibility checker, as you will be able to enter the wires you are seeing. From there, it will provide you with more details on what thermostats are compatible. Please let me know if that helps.
Hilary
Community Manager (Admin)
Have a great day!
Hilary
Hilary
Hey Folks.
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
Hilary
