02-21-2023 08:16 AM
I’m confused with the W/E wires
02-21-2023 09:24 AM
I'm having the same issue
02-21-2023 04:09 PM
You can ignore the jumper between the W/E terminal and the W2 terminal and just connect the White wire to the W2 or W terminals on the Nest and configure it as Aux Heat
02-22-2023 09:55 AM
Hey, can you tell me what wires go on the Nest, like where each wires need to be on, I can’t move on from the steps because it tells me to contact support
02-22-2023 08:15 PM
Give this wiring a try.
Black - C to C
Orange - O to OB or */OB
White - W2 to W2 or W (set as aux heat) (Jumper to W/E not needed)
Red - R to Rc or R
Green - G to G
Yellow - Y to Y1 or Y
The "or" is for the Google Nest Thermostat wiring
02-23-2023 10:08 AM
Thanks, is all working!
02-23-2023 10:10 AM
aux heat was automatically detected
02-27-2023 10:42 AM
Chiming in — I'm glad to hear that your issue is already fixed and thanks for the update. It looks like we have come to a solution, so I'm going to lock this thread in 24 hours. If you have any other concerns or questions, please feel free to create a new thread.
I appreciate your help @Patrick_Caezza.
