Need help with wiring for nest thermostat, please
reverserunner
The wiring of my tranditional thermostat is:
is this wiring for the nest thermostat correct?
Thanks a lot!
I’m sorry but this is not a correct response. The actual problem is you need to move the red wire from RH over to RC. Blue wire is indeed the common wire and does not need to be put in the *.
if you use the nest configuration tool as outlined in the installation manual, it should’ve told you to put the red wire in RC, and all the other wires exactly where you have them.
6 REPLIES 6
MrVacca
Silver Product Expert
If it's not already working, my suggestion is to move the blue wire that's located in your picture in the C slot over to the * slot.
Hi There @CoolingWizard - I stumbled upon your expert reply here and hoping you might be able to help me with my similar wiring question? I began a discussion here - https://www.googlenestcommunity.com/t5/Nest-Thermostats/Confirmation-Guide-to-wiring/td-p/286746
Dwein1107,
I posted a response for you.
Ken, The AC Cooling Wizard
Thanks for the help here, @CoolingWizard.
@reverserunner, awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
Thank you so much!  It is working and I am getting the heat now!
