07-14-2024 07:06 AM
I have Nest Learning Thermostat and need help to figure out wiring especially R and RC. I see small jumper wire between them. Does R wire go to RH and RC goes to RC in new thermostat? Thanks in advance. Here is the picture of current wiring:
07-17-2024 10:30 AM
Hi lolamlol,
Thanks for posting in the community! For sure, I can definitely help you with this wiring configuration on your Nest Learning Thermostat. Based on the photo provided, here you have an image with a recommended wiring:
Let me know how it works.
Axel.
07-17-2024 10:30 AM
Hi lolamlol,
Axel.
07-17-2024 01:44 PM
Thank you so much @AxelD ! I really appreciate the answer with image :).
