Nest 2 zone & Hot water
nads1978
I've just had a new (conventional) oil boiler and cylinder fitted.
I have 2 heating zones (separate valves) - Upstairs & downstairs. The Hot Water is a 3rd zone valve (S-Plus plan I believe).
It is all controlled by a 3 zone programmer, the 2 heating zones have wireless (battery) thermostats.
All 3 zone valves are in the airing cupboard with the junction box for the zone valves, the 2 wireless heating zone receivers and the circulation pump.
So, What products do I need?
Will my 3 zone programmer be replaced, what will control the hot water valve?
Hey nads1978,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Hey nads1978,
nads1978
I think I figured it out thanks.
Hey nads1978,
Glad to hear you got everything working. I am going to lock the thread at this time. If you run into any questions from here, please feel free to create a new post.
