Nest 3rd generation thermostat connect and disconnect from wifi
Rudy19
The thermostat is disconnected from the wifi this is the message I receive when checking the app on my iPhone.
I tried everything the troubleshooting section says: I replaced the battery, connected to a 24V common port to an outlet, restarted the thermostat several times, restarted the network several times, checked for interferences,  wifi signal is 69% on the thermostat, my network says that the wifi signal to the thermostat is excellent.  Every time it is disconnected, I go to the thermostat and check the network tab in the thermostat and it says connected and immediately the app on my iPhone shows connected.  Then one, two or three hours later the app says disconnected again and stays like that for days until I go to the thermostat again to check the status of the network. I do not know what to do because obviously, the thermostat is working even without the connection but I want to use the app to check the status and I can't. Any help would be appreciated.
2 REPLIES 2
BoV
Take a look at my post I just did….similar tech issue followed by customer service frustrations.
SoriaD_
Hello folks.
Thanks for reaching out to our Nest Community about this disconnection. I apologize for all the inconvenience. I'm here to help you with it.
I understand how frustrating this situation can be. Let us find a solution. Please Fill Out This Form to contact our specialized team. My team will determine the solution to your situation.
Feel free to keep us posted about your situation. I'm happy to find a solution for you.
Douglas.
