08-22-2022 06:17 AM
My Google nest Heat Link has stopped working.
I have 230V mains power across the input terminals, but the unit itself is completely dead.
I suspect something has blown on the Power Board circuit
Can you advise on how I source a replacement heat link only?
Thanks
08-23-2022 12:31 AM
Hey @Superflyjohnnys. I'm sorry to hear about your Heat Link. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
Cristian
08-26-2022 02:48 AM
Hi there again. I'm just checking in. Did you manage to answer the questions above? Let me know so we can carry on the process.
08-28-2022 03:40 AM
Hi, I wanted to check in. Do you need any further assistance? If so, make sure to let me know.
08-30-2022 04:07 AM
Since I haven't heard from you in a while, I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
