10-14-2021 03:39 AM
I had my Nest Thermostat installed 2 years ago by a Nest approved engineer and at the same time I had my boiler replaced.
It worked fine, then all of a sudden the Heat Link now has no power. There are no lights coming on, its totally dead. As a result the thermostat ran out of battery and is now dead, I manually charged this with a USB-C cable and now get the H72 error message. Having read lots on the forum, this appears to be a common issue with the Heat Link. Please advise?
10-27-2021 05:21 AM
Hello @Steve1,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones are present in the setup?
Cristian
10-29-2021 05:22 AM
Hello again. Just checking in. Do you still need my help?
11-09-2021 07:20 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
