12-04-2022 04:47 AM
When calling for cooling, the nest work for the first 10-15 minutes. Then temperate-warm air begging to blow out. When I checked the fan coil unit, both valves were open while under cooling. I thought that the nest was faulty, so I tried another one with the same result. When I pulled out the W1 wire ,which commands heat, the valve closed and cooling worked perfectly. In what instance would the Nest call for both valves to open.
I have a second nest thermostat in the apartment for a separate fan coil unit, same model and brand, just a larger unit, and I am not having the same problem. I tried both thermostats on this unit and it worked fine.
help!
12-07-2022 11:13 AM
Hi LeoT,
I'm sorry to hear that you're still having an issue with your Nest Learning Thermostat. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Mel
12-11-2022 02:52 PM
Hello there,
Thanks for helping, Mel.
@I'm checking back in — how's it going? have you had a chance to fill out the form? Let us know so we can assist you right away.
12-15-2022 06:18 AM
Hello LeoT,
I'm checking in to make sure that you've seen our response. If you have any further questions or concerns, please let us know before we lock this thread in 24 hours.
