01-31-2024 04:19 PM
Pro installed thermostats. One blinks red and green. It will not charge. Swapped for another Google thermostat, which worked fine. So that seems to mean the wiring is correct. What do I do next?
02-06-2024 02:06 PM
Hello NJN,
It seems you're experiencing some charging issues with your Nest thermostat. I'd be more than happy to assist you. First, let me confirm a few details. Is the display screen on your thermostat still visible, or does it completely refuse to power on even after attempting to charge it? Also, have you considered manually charging the thermostat using a USB cable connected to a wall outlet? What type of Nest thermostat are you using?
Edmond
02-07-2024 02:48 PM
Hi Edmond. We fully charged the nest. We out it on the base. It lit up. Then it went dark and has stayed dark all day. It remains dark.
02-07-2024 03:48 PM
I'm sorry to hear your Nest Thermostat isn't working out for you. We'd love to help you out with this. Could you please fill out this form? Once you're done, just let me know.
Edmond
02-08-2024 04:31 PM
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you.
Edmond
02-06-2024 02:14 PM
This went on for about a week. We are manually charging the thermostat and will know in the morning. It is a Nest learning model.
02-18-2024 02:06 PM
Google Nest Team - I replaced the non-responsive Nest Learning hub with a new one - which worked. The original will not work. Unfortunately, while troubleshooting with you, my time to return this defective item to Lowe’s expired (2/8/24). As the thermostat never worked and therefore never connected, I can’t get through your Warranty checker. I have the original box and a complete device set - but it has never worked and should be returnable to you,
