01-26-2022 11:05 AM
I installed the Nest Learning Thermostat a couple months ago and it was working fine, but I had to replace my old indoor and outdoor unit due to failure, mold, etc. My new outside unit is a heat pump from Ruud. It came packaged with a HoneywellHome T6 Pro thermostat and works correctly with it. When I try to heat with the Nest, the heat pump tries to turn on but makes a constant clicking noise and doesn't spin the fan.
The wiring for both thermostats is below (Honeywell - Nest)
Y - Y1
G - G
C - C
O/B - O/B
AUX/W2 - AUX/W2
R (internal jumper to Rc) - Rh (internal jumper to Rc)
The new system has a B configuration for the O/B valve, which is set on both thermostats.
I'm trying to understand why it works with the honeywell and not the nest, when I believe they're both wired and configured the same.
02-07-2022 09:11 AM
Hi zprimus,
Thanks for reaching out and we're sorry for the delay.
Let's try the following to further isolate the issue:
Let me know how it goes.
Ryan
02-10-2022 06:16 PM
Yes, I checked all of this. Flipping the O/B orientation either way just blows cool air out when I try to heat. On the B configuration (which is the correct orientation) the heat pump just makes a constant clicking noise. The wiring is as described above, and this honeywell thermostat works with almost identical wiring. I've had "heat pump" selected as the equipment during all of this as well.
02-10-2022 06:26 PM
Also the heat type and source are "forced-air" and "electric". The thermostat can see all of the wires connected since it displays them on the screen after I connect them. I don't know what the voltage should be for each terminal, but I could check that with my multimeter if I knew that info. I'm not sure if that's a value decided by the thermostat or the equipment.
06-26-2022 02:49 PM
Hope this helps!
Kind regards,
Ryan
