Nest Power Connector compatibility
JordanSpeak
Hello! We have a Nest 3rd Gen and it intermittently gives problems because the battery depletes. We don’t have a C wire running to the thermostat so I believe the solution would be adding the Power connector to our furnace wiring. Before doing so I wanted to check to see if the wiring we have is compatible with the connector.
Our system is a gas forced air furnace, and an AC unit (so heating and cooling). This is how the wiring is set up:
The black wire in C goes to the AC as does the red wire in Y2.
To the best of my understanding I should be able to use the following wiring setup to add the Power Connector (the C port would now have both the AC and the new connection from the Power Connector)
 Do I have the correct idea here? Thanks!
You indeed understand it correctly and the schematic is spot on.
AC Cooling Wizard
AC Cooling Wizard
Hello folks,
Thanks for confirming, @CoolingWizard.
@JordanSpeak, I'm checking in — how's it going? Still need our help with your Nest Power Connector's installation? Please let us know if you have any other questions or concerns.
Things should be good now! Don’t need to add the power connector quite yet (the power loss problems seem to happen in the summer more) but my question has been answered
Hi JordanSpeak,
Sounds great! I'm glad to hear it was sorted out. It looks like we can consider this one complete, so I will lock the thread within 24 hours unless I can help out with anything else.
