Nest Power Connector not working
jplatraverse
I just connected a Nest Power Connector to my two wire heat only nest and when I look at the diagram it is showing the 3 wires are all there (no errors) but the heat won't turn on when I put the heat on.  I am also seeing an error for n73 but I am confused because again the diagram is showing that all the wires are connected.  Has anyone run into this issue?
@jplatraverse
Are you using an external transformer? If you are, you need to pull a jumper.
2 REPLIES 2
@jplatraverse
jplatraverse
That I am not sure on, is there a way to connect the power connector directly to the nest and not the HVAC system?
