Nest Power Connector
CW2Higgs
Hey Community!
does anyone have an idea how to wire the Neat Power Connector to a Honeywell L7248A,C,L Oil and Electric Boiler?
Hey CW2Higgs,
I wanted to check in with you, and see if I could be of any help. I found an article with more details on compatibility. Please let me know if you have any questions from here, as I would be happy to take a closer look.
CW2Higgs
Hi Jake,
nope, still no luck.
Hey CW2Higgs,
Taking a closer look at the photos provided, I am showing there is a chance you may have a high voltage system. These systems are not compatible. High voltage thermostats are often built into the wall and typically have thick wires coming out of the thermostat. Wire nuts are often used to connect the thermostat to the system wires. In some cases, it is possible to make a high voltage system Nest compatible. I would recommend contacting a local pro for further help. Sorry about that.
Please let me know if you have any other questions from here, as I would be happy to take a closer look.
Hey CW2Higgs,
I wanted to follow up with you, and see if you had any questions. Please let me know, as I would be happy to assist, and answer any you may have.
EdwardT
Hi CW2Higgs,
I'm just checking in to make sure that you've seen Jake's response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
