Nest Power Connector
Pbourgea
I have a Nest thermostat connected to a 2 wire, hearing only system. I connected a Nest power connector at the heating equipment as per the instructions. The furnace cycles fine and I am able to control the temperature setting through the app. However I still get emails telling me that the thermostat isn’t getting sufficient power. Is there a way to verify that the thermostat “sees” the power connector?
David_K
If you’ve installed Nest Power Connector and your power status is “not detected,” try running a power test. The status should change to “detected” after the power test.
  1. Make sure your thermostat is set to Off mode.
  2. On your thermostat, select Settings > Equipment.
  3. Select Power Connector > Power test.
  4. Wait for the power test to finish, and then select Done.
  5. To confirm, select Settings > Equipment > Power Connector > Power Status.
  6. The screen should now read “Nest Power Connector Detected.”
aatienza
Hey Pbourgea,
I'd like to jump in here and check if you've seen davidking's response. Let us know if you need more help by replying to this thread.
I appreciate the help, davidking.
Archie
aatienza
Archie
aatienza
Hello there,
Archie
