09-17-2022 04:09 PM
I just installed two generation three nest learning thermostats. We have a geothermal system. Our AC worked fine before with the prior thermostat but now it’s not cooling. Below is the picture of the prior wiring configuration. I replicated this exactly with the nest thermostats. Appreciate any tips or tricks!
09-28-2022 03:52 AM
Hi BrendanG,
Thanks for reaching out here in the Google Nest Community.
It looks like you have a heat pump system and we could change the OB wire settings by going following the steps here.
I hope it helps.
Ryan
09-30-2022 08:02 AM
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
09-30-2022 09:59 AM
I ended up having to get a professional Nest installer come adjust the settings. It’s working now.
09-30-2022 10:23 AM
Hi BrendanG,
Thanks for updating us. Glad to know that everything is sorted out.
Since this has been resolved, we'll consider this as complete and will lock the thread in 24 hours. Feel free to start a new one if you need assistance with your Nest Thermostat and the community would gladly help.
Princess
