11-01-2023 06:54 PM - edited 11-01-2023 06:56 PM
I keep my thermostat on Heat/Cool mode all year. Today, the setpoints were at 72/78. It's currently 38 degrees outside my house.
I noticed around 6 PM that my Air Conditioning was on. It was 78 degrees in the house. I checked the thermostat, and it still showed 72/78. I went down to check the codes on the furnace, and it showed DFT, which means Defrost. (In Defrost mode, the A/C runs along with the heat to defrost an icy heat pump.) I did some research and it turns out that Defrost mode should only be used on Heat Pumps when it is chilly and very humid. But again, I don't have a heat pump. I changed the Mode on the thermostat to Heat Only, and rebooted the thermostat as well. For the last 4 hours, nothing has turned on since my house is still cooling off (naturally) from 78 to 72 degrees.
I don't know if the Mode change or the Reboot will do any good, but I'm curious to know if anyone else had an issue similar to this. Thanks!!
11-10-2023 09:53 AM
Hi zunkman,
Thanks for bringing this up here in the Google Nest community. Let's look deeper into this. Gather power reading of the Nest Thermostat:
For the Nest Learning Thermostat and Nest Thermostat E:
For the Nest Thermostat 2020:
In addition to this, send us a photo of your current wiring and setpoint while you are in heat mode. Also, if I may ask, are you getting any kind of error message on the Nest Thermostat?
Renz
11-10-2023 10:10 AM
Actually, I rebooted the thermostat and it hasn't happened again. I think something just got kerfuffled.
But, for the sake of information, no error messages. Battery 3.86, VOC and VIN both 35.36.
I can't send a photo of wiring and setpoint while in heat mode, since I always keep the thermostat in "heat/cool" mode. The problem occurred while in heat/cool mode, so debugging while in heat only mode would be a lesson in futility.
11-16-2023 09:12 AM
Hello zunkman,
Thanks for the update. Let’s continue observing the Nest thermostat and see if the same issue occurs. If the issue happens again, we’ll need to get a photo of your current wiring. To attach the image, you can go to this link: Google Nest Community Forum. Hit reply on the thread, and you'll see a camera icon or three horizontal lines to expand the toolbar, where you can click the camera icon and send your image.
Keep us posted.
Renz
