Nest Thermostat low battery, overheats when USB charging
KJC
3rd gen Nest Thermostat has been working fine for the last couple years. Now get message low battery, can't connect to WiFi. Charged on USB and device got very warm. Still shows low battery/can't connect when put back on base.
6 REPLIES 6
How is it wired?
EdwardT
@Patrick, thanks for the help!
@KJC, how's it going with your Nest Thermostat? Still need our help?
Edward
KJC
Had wiring, power checked by electrician. Moved the thermostat from upstairs to downstairs and still the same issue. Low battery, charged on USB, unit says to put back on base, unit gets hot from charging then when back on base thinks the room is HOT and turns on the AC.  And still get the same low battery message.
EdwardT
Hi KJC,
Thanks for the response. Could you share how your Nest Thermostat is wired? Also, please check the power readings of your Nest Thermostat. You can find this information by going to Settings > Technical Info > Power.
Edward
EdwardT
Hi KJC,
Edward
EdwardT
Hi KJC,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
