01-13-2023 02:00 PM
All is going well with the gen 3 thermostat, but I seem to be having a head scratching moment.
I cannot seem to set my hot water schedule to start a 4am! It just seems to select 4.30am and not any sooner!
Any suggestions?
01-14-2023 02:53 AM
Thanks for reaching out to us here @Rajsta. I am happy to hear that everything seems to be going well with the device.
The hot water schedule can be set on a 30 minute basis. So you should be able to set it at any fixed hour, like 04:00 or in the 30 minute increment at 04:30.
Here is some extra information on the hot water schedule that you can have a look at this link.
You can try and reset the hot water schedule and set it back up to see if that helps perhaps.
01-18-2023 02:05 AM
Hi there! Have you managed to try the previous message?
01-18-2023 09:04 PM
Yes I tried it with no effect.
I have managed to set the time now, it seems that there is a delay to the refresh rate on the app.
01-19-2023 01:40 AM
Could you please let me know if you re-set the hot water schedule on the thermostat or on the app itself?
01-22-2023 01:42 AM
Hi there! Just wanted to check if you managed to see my message above.
01-23-2023 06:20 AM
