09-02-2021 07:58 AM - edited 09-09-2021 11:04 AM
Original Poster: Jeff Wolf
Internal battery will not hold a charge and need to replace. Tried charging off base for overnight and still could not get a solid green light. Put back on base and works for a few minutes then drops below min and disconnects wifi, no display, etc. After a couple of hours the unit goes blank and HVAC does not work. Repeated above steps multiple times and get same results.
10-24-2021 12:32 AM
Have no solution for you except to replace battery. My 3rd gen Nest thermostat was working perfectly for about 2 years. Then, wifi started to drop. Now the thermostat can’t connect to wifi at all. Later on, it shut off by itself. Then, a prompt that battery charge is low & the unit needed to be shut down. Recharging the battery via USB revived it for a few days but the frustrating cycle started again. I’m focusing on the possibility of needing a battery replacement. There are a few batteries out there for my 3rd gen thermostat. Most (if not all) of them provide 3.7V 380mAh). But they don’t seem to meet the quoted spec from one of Google Gold product expert (for my 3rd gen thermostat: 3.7V 2.1 Wh=567.6 mAh). He didn’t state it specifically, but it’s implied that we all should go out & buy a new one to replace ours with bum batteries. It seems that Google should start thinking about making batteries for customers who need to replace their thermostat’s batteries. Hate to say it, but if I am steered toward buying a new Nest thermostat to replace my current one that is only 2-3 years old, I will definitely look for a different brand of thermostat, rather than staying with the Nest that doesn’t seem to last very long, and with Google doing a very poor job providing a logical (i.e. less expensive) fix. At least provide a trade-in program of some kind to keep us in your ecosystem, instead of letting customers’ frustration brew to the point that Google Nest products becomes synonymous with a Lemon. In the mean time, I will try replacing the thermostat battery with a 3.7V 380mAh battery that Is offered by many online merchants and see if it’ll solve the wifi & shut-down problems.
11-03-2021 06:48 PM
I’m in the same boat. I think I’m gonna throw this tstat away and by a different one. I’m not spend a couple of hundred dollars every 2 or 3 years. I won’t recommend nest tstat to anyone…..
11-26-2021 06:21 AM
Same-ish problem,
Since an update on November 2nd my less than one year old gen 3 Nest Learning Thermostat has now stopped working three times now due to a battery /charging issue. The first two times it actually charged on my desk using its USB port. It will no longer charge at all.
When connected to its base and I check its "Power" readouts though its settings menu it shows:
Battery - 3.852 V
Vin - 32.45 V
Vout - 32.45 V
lin - 200 mA(c)
All appear to be expected readouts.
Prior to Nov 2nd it worked flawlessly.
