Nest learning thermostat not cooling
Carranza822
Hello!
My c wires on my old thermostat had two wires connected on the same slot (one blue one white) idk which one I should connect on the new thermostat in the C slot and where to connect the extra one. Also, idk where to put my red Y wire. I connected it in y1 and it’s not cooling at all and I recall at first it said to put it in the O/B (Y red wire) but now it will only take it in the Y1 but it’s not cooling and it’s been 24 hours please help me someone
Hello Carranza822,
This an odd looking setup.  We need to take a look at the outdoor unit. It is possible that the white wire that was on C is the common being sent to the outdoor unit.  This would explain why you are not getting cooling when you ask for it.  Do you have access to the air handler / Furnace and the outdoor compressor unit?
The AC Cooling Wizard
@Carranza822, I saw your post and wanted to chime in. To better assist you please provide the information that we need asked by CoolingWizard, this will help us to move forward.
@CoolingWizard, thanks for your help.
EmersonB
@Carranza822 we wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
I appreciate the help, CoolingWizard and Jenelyn.
EmersonB
Hey Carranza822,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
