01-27-2023 12:26 PM
First thanks for any help I am given. I have a nest thermostat that is working. It runs with 4 wires. As I try to connect my Google power connector for the C-wire I cannot understand how to connect the 4 wires to the power connector. Cant upload a pic because of size The connections are as follows:
Yellow wire to Y
White wire to W
Green wire to G
Red wire to R
Thanks again
02-02-2023 08:09 AM
Hello CajunRican,
Thanks for reaching out. I understand the Nest Power Connector installation can be confusing, but I'm happy to help.
Installing the Nest Power Connector should be into your system control board, where the wires from your thermostat are connected. It's usually located on your HVAC system. For safety, please ensure that the power from your HVAC system at the breaker box is turned off before installing the power connector.
Here are some references to help you install your new Nest Power Connector on your HVAC system.
02-06-2023 02:22 PM
02-07-2023 02:56 PM
Hi CajunRican,
I'm checking in to make sure that you've seen my response. Please let us know if you have any additional questions or concerns before I lock this thread in 24 hours.
