01-13-2024 01:01 PM
How do I connect the nest power connector. I have force hot water heating system. I live in Andover MA here is attached picture of my system
01-17-2024 09:40 AM - edited 02-09-2024 01:58 PM
Hi vinodk,
Thanks for posting here in the Google Nest Community. I'd be happy to take a look at this for you. Based on the photo you sent us, you need to look for the control board, find the series of labeled terminals on it, and install the power connector there.
You can download the basic installation guide here.
In addition to this, you can visit our website, Nest Power Connector, to learn everything you need to know before installing the device.
Feel free to let us know if you have more questions or concerns.
Renz
01-19-2024 08:41 AM
I have force hot water heating system with 4zones and three control board aqua set where do I connect the nest power connector see attached picture of the system
02-09-2024 02:07 PM
Hello vinodk,
Apologies for the late response. Typically, the zone controller is part of the control panel located on an inside wall, most likely near your heating and air conditioning equipment. Based on the photo you sent us, you might need to open the control board panel; this varies depending on the make and model of your HVAC. If you are still unsure of this, we recommend contacting a Nest Pro to assist you or install it for you.
Keep us posted.
Renz
