12-21-2022 08:01 PM
Help! Over the last few days, my nest has started to act up. It's been working perfectly for two years. Suddenly, it'll now tell me that the heat is going when it's not. If I turns the mode to "off" and then back on "heat," it starts to heat up again for a few minutes before stopping again.
I tried to reset the device and I also did a factory reset with no luck. I did take it off the wall and plug it in for a good long while. It didn't indicate anything with the battery. I'm not sure if it charged or not and it's not an outlet issue.
a month ago
Hello JocisMom,
I'm sorry to hear that you're having issues with your thermostat for it's not activating the heat. I'd love to know more about this.
Could you share a photo of your thermostat's wiring with us? Are you getting any message codes or wiring reports? Also, please gather the power readouts from its settings under the technical info.
a month ago
Buzzing in — do you still need our help? Don't hesitate to reach back if you do.
Juni
4 weeks ago
Hello JocisMom,
Dan
