Nest takes ages to fire up boiler
Gh421
Hi guys. I recently wired up a nest learning thermostat to my system S plan boiler.
Everything works fine but from when I set the temp to when the boiler fires up takes a few minutes. With a conventional thermostat it switched on and off instantly.
Also the app is so delayed compared to what it says on the thermostat.
Did I miss something? Thanks in advance
Frustratedddd
Are you connected wired only? Try wired and wireless if you are.
Hi, I'm connected wired using the t1 and t2 ports.
Check to see if you are connected wireless also, that might help.
You should be wireless/wired, if not connect wireless as well.
