Nest thermostat and the wrong internal temperature reading issue
Matteo_Venice
I have had two 3rd gen nest thermostats for several years, one is attached to the wall, one is on the stand. These have always failed to read the correct internal temperature, introducing an error of about 1° - 1.5°. I work in the field of thermal engineering and Building Management Systems and have precision thermometers, so I am sure of what I am saying. It was useless to have followed the various guides and contacted support (one of the two thermostats was even replaced). After a long time I returned to the community and it is amazing to read how many people have this problem that was never taken seriously. And to think that the remedy would be really trivial, all it would take is to be able to run an offset. But Google is deaf because I see that many other suggestions also fall on deaf ears (reports and schedule management are also really poor). I must say that this is very frustrating, not least because we are talking about Google and a thermostat that does not come cheap. I now have them installed and manage the setpoints by increasing the desired temperature by 1 degree from the actual,
Someone from Nest explain to me, but what is the problem with inserting and managing an offset?
GabrielaG
Hi ,
Thanks for reaching out to the community and the feedback you provide us. I'm sorry to hear that your Nest Thermostats 3rd gen are having incorrect temperature reading issues. I'm happy to assist you right now.
When your thermostat has a delay, it is commonly called the maintenance band, differential, or temperature swing. The maintenance band allows the temperature in your home to change by a few degrees before turning your system on or off. To learn more about How the maintenance band works you can check this article.
Please consider sharing your thoughts directly with our development team through this feedback form. Your input will help us prioritize features and ensure that we're meeting the needs of our diverse user base.
Gabriela
