03-25-2022 01:20 PM
I set up the nest thermostat according to the video. At first the issue was that the red wire wasn’t power, so I looked it up and a solution was to change the blue common wire to the brown one. When I did that the red power was working but now the common wire wasn’t getting power. I contacted google support and their solution was to unplug the common wire and use the nest without it. I removed the common wire and now the nest says that the red wire has no power again. Can anyone assist me in this? @Nest
03-25-2022 08:43 PM
Post a picture of the original thermostat's wiring here
04-07-2022 07:24 PM
Thanks for answering, Patrick_Caezza.
BigBoyAmro, I'm jumping in to check if you still need help here. If yes. please provide the photo being requested above.
Melba
04-11-2022 11:27 PM
Hey BigBoyAmro,
Checking back in — how's your thermostat now?
Melba
04-12-2022 11:45 PM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
