11-30-2022 06:09 AM
I have a nest learning thermostat. I forgot the pin number. The thermostat is currently locked. In trying to get it unlocked, I inadvertently removed the thermostat from my Nest app. Now I cannot unlock my thermostat when I try to add the thermostat to my Nest app it asked me for the entry key. I cannot get to the entry key because the thermostat is locked, I have searched YouTube and Google for answers and I cannot find any. How can I unlock my thermostat?
12-05-2022 12:31 PM
Hello JoeV2,
Thank you for taking the time to let us know about your inquiry. I'd love to help.
To recover a locked Nest Thermostat that's disconnected from Wi-Fi or the Nest app, the only option is to manually unlock it. To do this, please follow these steps:
Let us know if you were able to locate the folder named "technicalinfo.PLIST" and what OS (Windows, macOS, or ChromeOS) of the computer you're using.
12-05-2022 02:57 PM
I am having a problem with the wire labels. I have 2 wires, a white one and a red one on my thermostat. The red one is labeled tn1 and the white one is labeled Com. I am not sure how to progress as these labels are not listed in our instructions.
12-06-2022 10:23 AM
Hi BP12,
Thanks for reaching out to this thread about your thermostat wiring configuration.
It looks like your concern is different from the original poster. In the meantime, you may check this link for more information. We also suggest you create a new thread, and we'll be more than happy to help.
12-09-2022 10:51 AM
12-12-2022 06:08 AM
Hi JoeV2,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
