Nest thermostat not heating or cooling
Jazmin07
I replaced my Honeywell thermostat with a google nest learning thermostat and now when it won’t heat or cool. I feel air coming out; when I turn heat on it is not heat and when I turn cool on it is not cold air. Also, I hear my hvac turn on outside for a few minutes then kicks off. My Honeywell was working perfectly fine but unsure what the problem is now. Can anyone help me troubleshoot?
I have pictures of my old thermostat and the nest but unsure how to post it on here
kayers11
are your wires correctly installed
I believe I did. I followed all the instructions, used the tags to label each wire and matched them to the correct inputs.
I wish I could post a picture on here but I’m not sure how to add photos on here
@Jazmin07
If the camera icon isn't present yet, you can use the imgur.com upload site and post the link it provides here.
