Nest thermostat temperature issue
GCHADHA
I have a nest thermostat and have recently been facing issues with maintaining right temperature.  I have tried different settings but even though I had set a temperature of 23 Celsius it took it all the way to 29 and experienced same issue with cooling. It's like it has mind of its own and doesn't work based on the input temperature. It gets too hot or cold all of a sudden. I have also turned off learning and auto schedule. Very unhappy and tired of this.
Hi GCHADHA,
Thanks for reaching out and for being a step ahead of us. I totally understand that troubleshooting can be frustrating, but these are the most helpful steps to isolate further what's going on with your device. Let's give them a try!
Please go to your Nest Thermostat Settings then select Home/Away Assist then turn it off. Under settings, look for Reset then choose Schedule to proceed with the reset. After disabling those two, monitor if the issue persists and let me know how it goes.
EmersonB
@GCHADHA, I'm dropping by to ensure that everything is covered here. How's it going with your Nest Thermostat? Were you able to perform the steps I’m suggesting? We'd be glad to hear from you.
I appreciate the help, Jenelyn.
EmersonB
Hey GCHADHA,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
