12-01-2022 02:28 PM
We have an AC unit for cold and a gas furnace for heat, hooked up to a Honeywell thermostat. I tried putting these 5 wires in respective slots on Nest thermostat (Y, G, C, W, R), but the nest did not seem to fire up the furnace. It was blowing cold air instead of hot when the mode was set to heat. What would be the correct Nest thermostat wiring for this system? Thanks.
12-05-2022 02:45 PM
HI fadikar,
Thanks for reaching out. I'm sorry to hear that you're having an issue when you call for heat with your Nest Thermostat. I'd love to know more about this and I have a few questions:
Edward
12-08-2022 03:40 PM
Hi fadikar,
Edward
12-12-2022 12:14 PM
Hi Edward,
I ended up installing a Honeywell smart thermostat and it seemed to work as intended with default wires.
Fadikar
12-12-2022 04:50 PM
Hi fadikar,
Thanks for the update. We're sad to see you go. We hope we can make it up to you in the future. Let me know if there's anything else.
Edward
12-15-2022 05:09 PM
Hi fadikar,
Since we have not received any more replies for quite some time, I will be locking this thread in 24 hours. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
