03-11-2024 08:34 AM
I'm looking for help on how to wire & setup a duel fuel system properly on the Nest Learning Thermostat(Gen3) with my new AC/Heat pump system and existing oil burner. I have read through many of the comments on this site and watched many videos, but I'm still not 100% on how this will work.
Systems
-Durastar (Rheem) AC/Heat pump (DRAH2TA3617ASTNNJ/DRHP15A30BJ1NA)
-Oil heat burner
I want to run on Heat pump until 40deg, then switch to oil burner
This is the current wiring:
Y1= Yellow (Directly from Rheem)
Y2=N/A
G=Green (Directly from Rheem)
OB=Blue (Directly from Rheem) (He said Nest must be set to use B)
Rc=Red (Directly from Rheem)
W1=White (Directly from oil burner)
C=Brown (Directly from oil burner)
RH=Red (Directly from oil burner)
With this configuration, I don't see how I can setup the dual fuel system. I was thinking the OB would move to W2 as the AUX, but I'm not really sure.
Thank you in advance for your support.
03-11-2024 08:42 AM
Just to be clear, the new system is one unit with AC & Heat pump combined. The P/Ns I provided above are:
DRAH2TA3617ASTNNJ - Air Handler
DRHP15A30BJ1NA - Compressor
03-14-2024 09:47 AM
Hello kkiteboy,
Thanks for reaching out! I'd be happy to take a look into this for you.
Setting up a dual-fuel system with the Nest Learning Thermostat can be a bit complex, especially when integrating both a heat pump and an oil burner. Here's a step-by-step guide to help you wire and set up your system properly:
Also, can you share with us your old thermostat's wiring setup? I'll look forward to your response.
