New home, water temp too low
Newhomeowner
Hi I have just moved into a home with nest thermostat, had several problems with boiler but that is now working, had to reset thermostat as previous owner did not logout but now can seem to find out how to turn my water temp up.
I set up on a combi boiler and heat is working fine but no separate water section?
george_t
Hi @Newhomeowner, thanks for reaching out. I'm sorry to hear about your issue, but I'd like to help you out. Please let me know if you have a combi boiler or system? Do you have a separate water tank? The hot water option is displayed only if you have a system boiler with a separate water tank.
GeorgeT
DragosC
Hi there. I'm just following up on our last message. Do you still need our help? Keep us posted.
Vladut
Hi there, as you haven't replied, we're just gonna go ahead and close the case. Let us know if you need anything else. Have a great day ahead!
