No Hot water
PaulLucan
Hi Everyone,please help
 No Hot water, while In schedule or on Boost ,sign stays gray in the app, can hear click in the heat link,but boiler not firing up. We have a system boiler . I tried to reset to factory settings,still no luck. Please help.thanks
7 REPLIES 7
Vladut
Hi there, thank you so much for reaching out. Can you tell me if it's a new installation?
PaulLucan
Hi Thanks ,Vladut, no ,we have it for years ,using system boiler.
heating is on fine ,but no hot water on even going manual from the heat link either.
Vladut
As you hear the click, and the schedule it's not working and also the manual mode, I'd recommend to contact an installer as it might be a stuck valve, damaged/loose wires or even the boiler.
PaulLucan
Sure ,I am waiting for one,thanks for your help
Vladut
Glad I can help. Let me know if you need anything else.
AlexD
Hi, just wanted to check in. How is it going so far? Did you get in touch with an installer?
TudorL
Since I haven't heard from you in a while, I'll close this conversation, but if anything comes up, you can always contact us, as we're a message away. Have a good day and stay safe!
