No Power Detected
NotSoLegendary
I'm trying to swap out my Jackson T-32-P thermostat for a nest thermostat. It looks to be wired correctly but it says there's no power.
@NotSoLegendary
When you swapped your original for the Nest, did you turn the HVAC breaker off? If you didn't, check for a possible blown fuse in the furnace/air handler.
Are you sure you have a heat pump and not a conventional system?
@Patrick_Caezza , it was indeed a blown fuse on the control board. Thanks for the reply!
Hey NotSoLegendary,
Thanks for the help Patrick_Caezza.
I am glad to hear everything is good to go from here. With that being the case, I am going to lock the thread in 24 hours. Let me know if you have any other questions from here, as I would be happy to review.
