No Power to Google Nest Thermostat after changing batteries
rcarpenter78
After changing the batteries to our Google Nest Thermostat, we plugged the Nest back into the wall and are now getting a No Power message (e298) and the wires are all listed as grey. Battery is good. Please help, we are in a heat wave!
Houptee
Does it light up and can you get to the diagnostic test to see what it says for voltage on Rc and common? Should be around 28 v AC give or take. If no voltage on Rc to common then the problem is in the system. Some control boards in the air handler have a fuse that could have blown.  They look like car fuses that plug in. If not then test with multi meter for the voltage at the transformer using a multi meter.
Ryan_G
Hey rcarpenter78,
Thanks for reaching out here in the Google Nest Community.
I'd like to jump in here and check if you've seen Houptee's response. It was a really good check for us to further isolate the issue. The error code E298 means that Nest Thermostat is not getting or detecting any power from your HVAC system.
Let us know how it goes by replying to this thread.
Thanks for your helpful troubleshooting, Houptee.
Ryan
Ryan_G
Hey rcarpenter78,
Ryan
Ryan_G
Have a great day.
Ryan
